ST170 Brakes
Old Jul 1, 2007 | 09:29 PM
adwfocus's Avatar
adwfocus
Default ST170 Brakes
Hi have a 2001 1.8 LX Focus and was thinking about fitting ST170 brakes to the front of it but I am unsure if the wheels will house the brakes because the ST brakes are a lot bigger than my stock brakes I am still running the stock 15" LX wheels from the Mk1.5 focus, I am not really wanting to replace the wheels if i can as i want to keep the stock sleeper look as it has a few mods to the motor that has 180bhp and is very underbraked. I know what items are needed for the conversion but not sure about the wheels if a pic of the wheels are required one can be posted ok.
Thankyou for your time replies would be greatly appreciated
Cheers.
Old Jul 2, 2007 | 06:59 AM
It's a pity that you don't know someone with one(st170) that you could try your wheel on.
Failing that, I don't see that they are going to fit, most 15" have 335mm or thereabouts clearance(inside), ST170 = 300 discs plus caliper, so it's not going to.
What about the cossie route ?, four pots and 283mm discs.
Old Jul 2, 2007 | 05:31 PM
adwfocus's Avatar
adwfocus
Thanx for that I have never thought of the cossie brakes I have no clue of what would be involved in the cossie brake conversion??? maybe if someone could give me some help on this matter??? There is a lad from my work who's brother had a ST170 but i dont know his bro so maybe give him a shout and see if he will let me try my wheels on his ST??
Old Jul 3, 2007 | 04:39 AM
Ford use pretty much the same dimension lug mount wise for the brakes on their hubs, I would be surprised if they, cossie 4 pots did not go straight on.
Old Jul 4, 2007 | 11:41 PM
pdfbt40's Avatar
pdfbt40
You have to use 16" wheels with ST170 brakes. That's why it gets that funky orange alloy for the spacesaver spare. Even then some will not have sufficient clearance.
As you know, the standard knuckles have to be changed usually as they, for some reason, do not follow normal Ford lug design, but the ST170 does. Whilst it has the standard calliper lug dimensions, albeit with M12 bolts, the offsets are different.
This can be illustrated, for example, by the need to use 10mm (?) spacers when using ST170 discs and callipers (or Mondeo Mk3 callipers) on an Escort knuckle. Going the other way onto a ST170 knuckle with another Ford calliper might be difficult.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
