cold start!
Old Jun 25, 2007 | 09:11 PM
rsgav83's Avatar
rsgav83
Default cold start!
Hi everyone i am quite new to this!!
The problem i am having is my s2 erst trying to start from cold it takes a lot of cranking before it fires up then it will be fine! I have took the cold start injector out of inlet manifold and wired it up turned ignition on and thought there should be a spray of fuel but nothing happen does anyone think that is my problem??
Any help i would be very greatfull!!
Old Jun 26, 2007 | 12:04 AM
antony215's Avatar
antony215
Escort Rs Turbo
The cold start valve only sprays when you crank the engine over not when you just turn the ignition on.
Old Jun 26, 2007 | 11:27 AM
SafeChav's Avatar
SafeChav
They are shit anyway, try unplugging it and i bet you a jam tart it starts better than it ever has
Old Jun 26, 2007 | 12:36 PM
Phil79's Avatar
Phil79
Agreed
Old Jun 26, 2007 | 05:08 PM
syko2005's Avatar
syko2005
burning oil
same here disconected mine because it used to take ages start. starts mint now
Old Jul 1, 2007 | 03:26 PM
rsgav83's Avatar
rsgav83
Default cold start!
Cheers guys will have to try this monday when i go into work!
your right about when it spays cranked it over and fuel did spay out!!
Have to unplug it and give it a go!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
gingeRS
Sep 4, 2015 06:29 PM
