fault code clearing
Old Jun 23, 2007 | 09:51 PM
jayRS's Avatar
jayRS
Default fault code clearing
i know no fucker will post up on this but gunna ask anyway.
2 litre petrol galaxy.
fail mot on emissions due to lambda sensor being fucked, so replaced, and it drives a lot better and no flat spot, so alls well, but although it passed mot emissons were still high, was told it was fault code.
how would i clear it on the galaxy? been told disconnect battery which i was gunna do anyway and leave off for half hour, then someone said about turning ignition on and off a few times.
just wanna know if anyone has done it on a galaxy
Old Jun 23, 2007 | 10:38 PM
captiva's Avatar
captiva
Default Re: fault code clearing
Why don't you use the Queens English rather than your GUTTER language and then may be someone will help you
Old Jun 23, 2007 | 10:40 PM
costina's Avatar
costina
Live long and prosper!!
Got a Galaxy i'd go for the battery mate
theres something in the manual about ignition but i think its for resetting the service light..
Most cars clear if u disconnect the battery
Old Jun 24, 2007 | 05:25 AM
The galaxy as all other cars use a KAM, or Keep Alive Memory circuit, most will have a separate FUSE for this one circuit.
This holds all the refined running adjustments and the memory, so pull this to clear it, this has the added advantage of clearing a wrong learnt value due to a dodgy sensor.
Having a fault code will NOT alter emissions as it works from the base map when there is a change due to sensor change.
It MAY not even have flagged a fault code anyway, unless way out of sync, if it was still within running parameters no fault will have been detected, this is the problem with ECU fault reporting, and the dire lack of diagnostic skills taught these days.
If there is no fuse marked KAM, then just disconnect the battery for 5 minutes is plenty.
Old Jun 24, 2007 | 01:21 PM
jayRS's Avatar
jayRS
gutter language fuck off cunt lips, no one asked you to reply just cos you dont like my english..
bollocks now go play with the traffic
will have a look fella.
reason i reckon a code was given was the fact mot guy said it was off the scale, fitted a new sensor and he said it was worse.
still took it somewhere else and they got it right down, they reckon it could be the exhaust as i welded a hole up in it to get it through mot as not got cash till next month to get one.
cheers dude
Old Jun 24, 2007 | 01:25 PM
costina's Avatar
costina
Sorted it yet jay???
Old Jun 24, 2007 | 01:27 PM
jayRS's Avatar
jayRS
only just got the replys today mate, hotmail account been playing up.
not done nothing to it as yet, but will be tomorrow mate
Old Jun 24, 2007 | 03:17 PM
Knuckles's Avatar
Knuckles
Well put jay - i would of put it a lot more aggressively than that.
If you ain't got nothing good to say - Fuck off !
Old Jun 24, 2007 | 03:27 PM
jayRS's Avatar
jayRS
ah well, cant please everyone with the way i am, seems only english people can take it in jest
Old Jun 25, 2007 | 06:54 PM
NEWTON's Avatar
NEWTON
cheers dude
tankybaby66
Feb 6, 2016 02:24 PM
Fil
Sep 30, 2015 12:08 PM
stevecfrst1
Sep 30, 2015 05:18 AM
