Mk6 Escort
Old Jun 23, 2007 | 02:45 PM
Drewman's Avatar
Drewman
Default Mk6 Escort
How easy is it to fit a rev counter to this? standard, not aftermarket.
How do you do it?
S-Reg Encore by the way
Old Jun 25, 2007 | 01:40 PM
messcortmk6's Avatar
messcortmk6
im asking the same question here, mine had a gay picture of a car there that does nothing. i want standard ones too like the rs2000 style.
Old Jun 28, 2007 | 09:53 PM
Drewman's Avatar
Drewman
This may help messcort
Taken from another forum:
hi there
im new here but just did my rev counter on my 1.6 chicane
first get some mk6 clocks with rev counter
then go to passenger footwell take off cover and there is the ecu
pull it out (it slides after removing 10mm bolt)
on pin 4 you will see a white and black wire (scotchlock or similar into it
this one goes to pin 8 on the blue connector on the back of the clocks
if you have a spare connecter (scrapyard) you can take the connector out and put it in your plug easily
put it all together and away you go
let me know if you understand as its easy really
Old Jun 29, 2007 | 11:09 PM
messcortmk6
where did you get this from im not understanding that bit in brackets about scotchclock and pin 8????? can you help me please thanks
Old Jun 30, 2007 | 08:03 AM
Drewman's Avatar
Drewman
it was from http://www.feoc-uk.com/ a ford escort forum, do a search and theres a few things on there about it fitting a standard rev counter.
Basically, you're cutting into the wire from pin 8 and sending that to the tach, a scotchlock allows you to "steal" signals from the wire that you are scotchlocking. Think of a T-junction.
Old Jun 30, 2007 | 04:37 PM
messcortmk6
thanks, but one more thing, pin 8? do you count the horizontally with the top line first then to the botom line till you get to 8 or do you count top bottom top bottom till you have 8?
Old Jul 1, 2007 | 04:48 PM
Drewman's Avatar
Drewman
I haven't actually looked mate but i would imagine from top left and then bottom right and you should find the white and black wire but as said I don't really know
Old Jul 4, 2007 | 11:26 PM
messcortmk6
dont worry solved it!!!! i got a post on general!!
Old Jul 5, 2007 | 04:45 PM
Drewman's Avatar
Drewman
ah cool plugs straight in then, I hope my flight's gonna be the same
Old Jul 5, 2007 | 05:43 PM
messcortmk6
i was surprised because all of the connector pins look really odd on the plugs. i didnt think it would work but she started straignt up, i love it, and it saves fucking about with wiring aswell.
woop woop
Old Jul 5, 2007 | 05:46 PM
messcortmk6
but what i honestly dont understand is why did they make them different if they just plug in??? why not mass produce the gti style ones, would be so much cheaper for ford........
hmmmmm..
rex647
Mar 6, 2022 06:20 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
