can someone help?
Old Jun 22, 2007 | 05:33 PM
Moose's Avatar
Moose
Default can someone help?
Im after doing the EFI conversion in my S2 but im after running it on cossie management, is it an easy option to go for i.e do i need all cossie sensors and is the management a fairly simple conversion to do, hope someone can clear it up a little.
cheers
rich
Old Jun 24, 2007 | 02:28 PM
jayRS's Avatar
jayRS
yes its fairly stright forward, you will of corse need the efi inlet manifold and your need a adaptor plate as the erst head doesnt have the cut outs for the injectors.
ifyou dont want to use a dizzy then your have to have the cossie stuff converted or just run FRST set up
