Racetech oil press/temp gauge fitment on sierra cosworth
Hi i rencently got my hands on a Racetech oil press/oil temp gauge.
complete with the oiltemp sender en pressure pipe.
the oil temp sender comes with a male/male adaptor. But seems to big to fit in as a oildrainplug. Where would you have it located?
The pressurepipe i can take off where normally the oil pressure switch is located?
many thanks, Istvan
many thanks, Istvan
You can cheaply buy adaptors to fit the two threads together sump plug/oil sender if you want.
Best place for these is probably a large AIR COMPRESSOR spares shop, or maybe where you got the gauge ?
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
