lame - suspension problem
Old Sep 22, 2004 | 10:22 PM
Azrael's Avatar
Azrael
Default lame - suspension problem
I just came back home after evening drive and I got problem which I don't understand. Maybe this is some peculiarity of Ford suspension and somebody will know. Tha car drives and behaves as normal in all conditions apart from left hand corners above 100km/h where I encounter sever vibration of left front wheel. It feels like maaaaasive suspension problem or square wheel but on straight, in tight corners and all the righ handers it is all right. What can it be? Wheel bearing? It's the only thing I can think of but then it should be really loud and noisy.
Old Sep 25, 2004 | 09:49 PM
blaazer2's Avatar
blaazer2
check your front diff ,also engine mounts
Old Sep 26, 2004 | 04:42 PM
Aaroncast's Avatar
Aaroncast
hi, ive got an escort cossie--666cos i had a simular problem to yours a while ago it took me ages to find out what it was!!!! and it turned out to be the down pipe from the turbo<85 mm>touching the chassis/steering!!!!!! the nuts/bolts had slightly loosend and caused the exhaust to move over /twist!!! just check your clearance before condeming suspention--glynne notts--glyn.williams3@ntlworld
Old Sep 26, 2004 | 09:33 PM
Azrael's Avatar
Azrael
Thanks for that one. this is what I am currently suspecting. But there can be a problem, after some more driving I must say thare is something wrong with the steering - just don't know yet if the two are connected. On the steering side I am suspecting the time is coming for the steering rack itself.
Becka674
11
Oct 8, 2015 03:11 PM
Russ Payne
Sep 25, 2015 08:29 PM
L1AM_RS
Sep 23, 2015 03:27 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
truffleshuffle
Sep 10, 2015 09:35 PM
