Valve stem oil seals
Old Jun 8, 2007 | 08:00 PM
mk4gartrac's Avatar
mk4gartrac
Default Valve stem oil seals
Whats the best way of removing them on a 4wd cosworth cylinder head?
Old Jun 9, 2007 | 06:28 PM
messcortmk6's Avatar
messcortmk6
take the valves and springs out, then squeeze them with needle nose pliers, but squeese all round till they loosen, then just pull them but dont be to violent!!!!!
eay job once you done 1 or 2 of them you will find it easy.
Old Jun 9, 2007 | 06:45 PM
neil andeRSon's Avatar
neil andeRSon
good question.. i've just started to strip my head down...
Old Jun 11, 2007 | 06:23 AM
mk4gartrac's Avatar
mk4gartrac
and to replace them?
Old Jun 11, 2007 | 04:28 PM
Red16's Avatar
Red16
to remove them if theyre very hard sometimes you have to split them down the side, being very careful not to damage the valve guides.
refitting them i normally use a 12 point socket and a bit of wd40 to push them onto the valve guide
never had any problems doing it this way
Old Jun 11, 2007 | 10:14 PM
messcortmk6
yeah, to refit them you just have to push, use oil to slip them on, its nicer.
so how have you got on with it?? did you get them off okay?
Old Jun 13, 2007 | 05:14 PM
mk4gartrac's Avatar
mk4gartrac
just got a pair of valve stem seal pliers ill let u know how i get on
Old Jun 15, 2007 | 07:03 PM
mk4gartrac's Avatar
mk4gartrac
Nope there not moving. EVER!
Old Jun 15, 2007 | 07:43 PM
mk4gartrac's Avatar
mk4gartrac
Well ive had to very carefully split them ive got 2 off so far
Old Jul 10, 2007 | 07:12 PM
mk4gartrac's Avatar
mk4gartrac
Right im not having a good time with these oil seals im on my second set now the i have been oiling them and taping them on with a 12 mm socket and even bought a valve stem installer but the rubber keeps stripping out from the inside ive only managed to get a couple on without damaging the rubber any advice would be super
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
krypton
Sep 23, 2015 07:29 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
