floorpan/mountings
Old May 30, 2007 | 09:01 PM
DROPTOP's Avatar
DROPTOP
Default floorpan/mountings
what difference is there between a 2L i ghia sierra (for example) and 2wd saff cos in the way of engine -box and diff mounts? . is the cos stuff a straight swap fitment wise?
Old Jun 3, 2007 | 08:51 PM
DROPTOP's Avatar
DROPTOP
come on girls im about to start cutting the tunnel in my 944 and need to know what non cosworth sierra i need to buy to cut up and graft to the 944 that will then (after its tested) accept all 2wd cos stuff. a minute of your time ?
Old Jun 3, 2007 | 08:58 PM
Azrael's Avatar
Azrael
AFAIK it's all the same apart from Cossie Sierra having larger cut outs for wiring looms.
Old Jun 3, 2007 | 09:19 PM
DROPTOP's Avatar
DROPTOP
so a 2l dohc saff would be spot on then. just need to find one close by now , not as many about nowdays.
Old Jun 4, 2007 | 01:19 AM
jon@work's Avatar
jon@work
get yourself down to Loom's - there's loads in there
Are you sure there isn't room in the tunnel you've already got ? It would be a hell of a lot easier making up local mounts/reinforcements for the rear beam, gearbox, and prop centre joint, than fitting a complete sierra floorpan, if that's what you are intending to do.
Old Jun 4, 2007 | 07:48 AM
DROPTOP's Avatar
DROPTOP
hows it going mate . its more so ive got something to work to and all the bits there at hand. plan is to use bits of the sierra floorpan where needed/possible rather than fab all new brackets but untill theyre both in the air theres no knowing . what/wheres looms?
Old Jun 4, 2007 | 08:01 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I dont think you'd need a saff, any mk2 sierra would do. They've all got the same floor pan iirc.
Old Jun 4, 2007 | 08:16 AM
DROPTOP's Avatar
DROPTOP
good good scrapyard search is on then
Old Jun 4, 2007 | 11:34 AM
jon@work's Avatar
jon@work
Albert Looms - big yard at Spondon (before you get to Pride Park on the A52)
Old Jun 4, 2007 | 06:08 PM
crash_ash's Avatar
crash_ash
i'm in newark and someone round the corner from me has been trying to pedal a K plate "cossie rep" saff for £295ono for a while, if thats any help
Old Jun 4, 2007 | 08:00 PM
DROPTOP's Avatar
DROPTOP
pm'd
