Tyre wear
The inside of my front tyres look like that are wearing, new alloys have only been on few weeks
, i didn't do the tracking but was done when i had my last set on, all seem balanced, could it be suspension?
big wheels will always have the problem more even on a standard car.
Adjustable bottom arms are going to be rquired if you don't want to be replacing tyres every few thousand miles
15's are a whole inch larger & will/may cause this problem as safechav says!! Tracking can also drift to to wear in other suspension components so although you have had it checked is doesn't mean to say it is correct now. Always worth the extra couple of quid to get the geometry checked & set if need be when fitting new wheels & tyres!!
Andy
Andy
Get some new wishbones and remove the riveted balljoint by grinding away the top of the riverts , then drill new holes for the balljoint 15m further in and cut off the end of the arm to shit
This will not stop it but the tyres will last alot longer
tracking needs doing at least once a year if they are both going on the inside edge i bet thats what it is im in the car trade so i would place my money on it being the tracking get it looked at
its probably camber, if ur front suspensions are McPhersons then u can try H&R's camber bolts.. another option for a McPherson strut are adjustable upper mounts
for a double A setup, there are adjustable upper arms in the aftermarket
Fitting a larger diameter wheel will increase the effects of whatever camber yopu already had though, it will of had small amounts of negative camber anyway, but by fitting larger, wider wheels with lower profile tyres you will notice the wear more.
