Wide Band Lambda...Experts please???
Old Jan 10, 2004 | 07:54 PM
CosRush's Avatar
CosRush
Default Wide Band Lambda...Experts please???
Now ive heard that many of the Fuel/Air ratio meters you can buy to go in the car are pants, cos they dont read a wide range.
If this is right, is there any benefit from using a wide band lambda as they seem to be going quite cheap in places?
Or dont they work like that
Cheers.
Old Jan 10, 2004 | 08:24 PM
the original's Avatar
the original
if u do a search there was a thread or two about this already.
i use a 5-wire wideband with tech edge box and display and wouldn't be without it now.
cheers
Old Jan 10, 2004 | 08:29 PM
the original
paul hills commented on it and didn't cuss it down.
it's using the honda sensor.
has datalogging capability + 2 other channels if u connect to laptop
Old Jan 10, 2004 | 08:34 PM
the original
covers something like 8:1 rich down to 20:1 weak or something like that
cheers
Old Jan 10, 2004 | 08:55 PM
JesseT's Avatar
JesseT
I have the same unit and it's just fantastic.
http://www.techedge.com.au/vehicle/wbo2/
Doesn't even cost much if you assemble it yourself.
Old Jan 10, 2004 | 10:04 PM
the original
have you hooked it up to laptop or one of those palm things yet?
Old Jan 11, 2004 | 02:08 PM
JesseT's Avatar
JesseT
I have hooked it up to the fuel injection ecu and then that to the laptop. So only indirectly. Nevertheless, the values can be datalogged.
Cosnada
Jan 7, 2016 05:30 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
benw456
Sep 16, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
