Focus water leak
Old Apr 30, 2007 | 06:46 AM
griff488's Avatar
griff488
Default Focus water leak
For about the last year i have been having a water leak from where the thermostat housing bolts to the head. I have replaced the seal several times but to no avail. It still leaks!!!
Has anyone had this problem before and how did you fix it?
Cheers Griff
Old Apr 30, 2007 | 10:41 AM
antony215's Avatar
antony215
Escort Rs Turbo
Makesure you cover the gasket with gasket sealent and that you torque the bolts to the right setting
Old Apr 30, 2007 | 05:29 PM
o n i o n's Avatar
o n i o n
You'll need a new plastic housing.
Quite common, not sure how much they are.
Old May 3, 2007 | 10:47 PM
phill295's Avatar
phill295
if its a 1.6 zetec se then you will need the whole housing i think there about Ł20 and easy to fit hope that helps
Old May 4, 2007 | 06:59 AM
LOCTITE 5910 will seal it 100% perfect.
Old Jun 19, 2007 | 11:50 PM
phill295's Avatar
phill295
sealant does not stop it i found out the hard way at work had to do the job twice
Old Jun 20, 2007 | 06:52 AM
Loctite 5910 DOES stop it, done a few myself, it also sticks on arch extensions door mouldings etc etc etc, awsome stuff but expensive/ish.
It also works on deep sea goggles as mate used it, though he should have bought a new pair!!
I have also used it to stick on SUMPS with NO gasket as car was so old could not get any, I had to LEVER the sump off afterwards when I stuck it on my xr4i, then spend an hour straightening the sump!!
I have NEVER had a leak with this stuff ever from anywhere.
Worst bit is getting hold of it, as not many places stock it.
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
