URGENT help!! Aaaarrrh!!
Old Sep 16, 2004 | 01:24 PM
K3V HA's Avatar
K3V HA
Default URGENT help!! Aaaarrrh!!
Just been out in my car (2ltr ZVH), now once it had warmed up, it was running fine (as usual), running upto 15psi, but after about 10mins, the car felt really slow, and is only boosting upto about 5psi? If i keep my foot down, it goes up to about 10psi but takes an absolute age to get there? What could it be? Ive got all samcos etc so dont think it will be a split hose?
Please help as im supposed to be running at santa pod at the weekend!!
Old Sep 16, 2004 | 01:47 PM
Stu @ M Developments's Avatar
PassionFords Creator
It sound's like one of the following:
1) A blown hose or similar.
2) Leaking dump valve.
3) A dead Amal valve.
4) A dead turbo.
5) fault with wastegate
Old Sep 16, 2004 | 01:48 PM
K3V HA's Avatar
K3V HA
4) A dead turbo.
Cheers Stu, the turbo is still spinning though, is tha ta good sign? Aint got a dump valve, so cant be that, where is the amal valve? Ill check the hoses now!!
Old Sep 16, 2004 | 01:54 PM
foreigneRS's Avatar
foreigneRS
Testing the future
broken wastegate/actuator?
Old Sep 16, 2004 | 01:56 PM
K3V HA's Avatar
K3V HA
I thought that, how hard are actuators to take off/fit? My mate has got a -31 on his turbo that i may be able to borrow??!?
Old Sep 16, 2004 | 01:58 PM
Jim Galbally's Avatar
Jim Galbally
amal valve is ontop of the gearbox, circle thing with 3 hoses coming off of it, hoses goto airbox, turbo housing (or crossoverpipe, depending on how its set up) and wastegate actuator
also has 2 electrical connections on it.
unless ofcourse it has a bleed valve fitted betweena hose running from turbo to actuator... in which case ignore the amal valve coz its been bypassed and its not your problem
Old Sep 16, 2004 | 02:07 PM
K3V HA's Avatar
K3V HA
Pretty sure its got a bleed valve on it Jim,
Anyoen know of anywhere in the notts area i could take it to get checked out??
Old Sep 16, 2004 | 02:34 PM
DOO's Avatar
DOO
acutator has come loose 100%
Jim Galbally
notts? aint jamsport near there? they know their RSTs
Old Sep 16, 2004 | 02:37 PM
K3V HA's Avatar
K3V HA
How do i thighten it up mate??
Lee R's Avatar
Lee R
Jamsport are in Northampton
Old Sep 16, 2004 | 02:39 PM
foreigneRS's Avatar
foreigneRS
Testing the future
to roughly check your actuator, get a pair of pliers on the rod or the wastegate and try to push it towards the actuator. the spring inside should work against you and be quite hard to push. how hard is hard, and if it's hard enough to give you the required boost is hard to say. check to make sure that the bracket isn't cracked or flexing or anything.
Old Sep 16, 2004 | 02:55 PM
If actuator comes off you cant make ANY boost at all...
Old Sep 16, 2004 | 02:57 PM
K3V HA's Avatar
K3V HA
Where do i tighten it up?? Ive had a look, but cant see??
Old Sep 16, 2004 | 11:00 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
with the 2 bolts on the actuator lol you will see you have my no kev call me n ill tell u
Old Sep 17, 2004 | 07:47 AM
K3V HA's Avatar
K3V HA
Ive sorted now Gus i think, it wasnt the 2 nuts, it was the actual bracket that hold the actuator in place!! Cheers for the offer though mate, i might ring you again if anything else goes wrong!!
DaveN
13
Jan 9, 2005 06:19 PM
R4N SS
Jan 1, 2005 12:17 AM
Walshy
May 14, 2004 01:34 PM
