Dead ABS
Old Jan 9, 2004 | 01:18 AM
Default Dead ABS
Anyone got any ideas as to why my ABS no longer works on my 2WD sapph?? Changed 1 of the leads last year,don't think it's worked since...
Old Jan 9, 2004 | 11:05 AM
ummmm did you break it perhaps?
Old Jan 9, 2004 | 10:57 PM
PJay's Avatar
PJay
Best thing for it IMO
Old Jan 10, 2004 | 02:03 AM
lol
Old Jan 10, 2004 | 09:27 PM
Cheers for the advice,i'll know not to post on here for serious advice from now.
Old Jan 10, 2004 | 09:50 PM
sorry plynchy but without looking at your problem in the felsh its bloody hard to guess what you did to it when you had a play with it last.
drive it to coventry and i would be happy to look at it and tell ya what the problem is
Old Jan 13, 2004 | 06:10 AM
Can't drive it cos it's in hibernation! Changed one of the front sensors as it broke whilst trying to remove the front stub axle.Got a brand new item from Ford but hasn't worked since(i think). Didn't find out till a few months later when the wheels locked under some serious braking.
Old Jan 13, 2004 | 12:38 PM
well sounds most likely to be a duff sensor that ford suplied you then mate.
Old Jan 13, 2004 | 12:40 PM
Alvyn's Avatar
Alvyn
DOES THE LIGHT COME ON???if not have a look @ the fuse on the abs relay thats under the passenger side of the dash m8!
Old Jan 13, 2004 | 04:12 PM
Cheers Alvyn.By the way Darren,wots "felsh" ?
Oh,the light doesn't come on.
Does anyone know what resistance the lead should read??
Old Jan 13, 2004 | 04:38 PM
Alvyn's Avatar
Alvyn
Default ABS TEST
1:get in the car push your foot on the brake pedal and hold it pushed down.
2:turn your ignition on and the pedal should move down(only a fraction) as well as this you should hear a click!
BUT 1ST CHECK THE FUSE AS I SAID ABOVE M8!
hope the above can sort your prob m8!
Old Jan 13, 2004 | 05:50 PM
[quote="plynchy"]Cheers Alvyn.By the way Darren,wots "felsh" ?
hey it was late and i had a long day
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
