charging probs
Old Mar 27, 2007 | 06:46 PM
sy.rst's Avatar
sy.rst
Default charging probs
iv got a series 2 rs turbo,iv changed the alternator twice,the battery twice and still its not charging.iv put my multimeter on the red wire on the back or the alternator and its only showing 10volts,iv cleaned the main battery earth lead aswell.the car is my daily driver aswell so need it to be running to get to work.
Old Mar 27, 2007 | 06:58 PM
o n i o n's Avatar
o n i o n
does your battery light light up when you put key in position 2.
You could've blown the battery light bulb,
Or more common, is the thin blue wire from your alternator to you speedo head gets very hot and brittle and can break. Normaly along the fron anti-roll bar somewhrere near the black connector.
Hope this helps buddy.
Old Mar 27, 2007 | 07:15 PM
sy.rst's Avatar
sy.rst
no the battery light doesnt come on , can that stop it chargeing then.
Old Mar 27, 2007 | 08:34 PM
o n i o n's Avatar
o n i o n
yeah it can.
When I say ign position 2 i meant ign on but engine not running.
That's where you need to start.
Old Mar 27, 2007 | 09:23 PM
sy.rst's Avatar
sy.rst
no it does not come on at all.i will try that 2moro. thanks for your help.
Old Mar 29, 2007 | 12:32 AM
SafeChav's Avatar
SafeChav
If the battery light doesnt come on check the thin blue wire running to the alternator, common to break!
Old Mar 31, 2007 | 07:32 PM
escrst's Avatar
escrst
as above. thin blue wire mate. always a problem
gcfcos
59
Oct 6, 2015 05:04 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
jay030787
Sep 18, 2015 04:38 PM
Cos500
Sep 16, 2015 09:50 PM
gcfcos
88
Sep 15, 2015 03:48 PM
