cossie not sparking
Old Mar 17, 2007 | 05:21 PM
muffster's Avatar
muffster
Default cossie not sparking
Hello.
Any ideas on this anyone?
I adjusted the distributor very slightly because one of the leads was pushing right up against the inlet manifold and now im not getting a spark at all!!! Even though the adjustment was vey small, would that be enough to put the timing out completly?? I dont think im getting anything from the coil.Can anyone help, please.
Muffster.
Old Mar 17, 2007 | 08:32 PM
It does not matter what position the dizzy is in, if everything working ok you will get a spark just at the wrong time that's all.
Have you inadvertantly disloged a connector ?, do you have a dodgy CPS connector as these do play up ?, have you checked the phase gap ?
Take king lead out of cap and rest near body work then turn over and see if it sparks, if like me you may have forgotten to put the rotor arm back in.
Old Mar 17, 2007 | 09:07 PM
PeterLucas's Avatar
PeterLucas
time the engine up with the two camshaft pointers pointing at each other and then line the rotor arm up with the notch on the distributor housing. I think the rotor arm needs to be within 20 degrees of this mark.
Also check your phase sensor wires, if youve disturbed them its very common that the insulation just falls of and the two wires touch.
Good luck!
Old Mar 17, 2007 | 11:22 PM
muffster's Avatar
muffster
Thanks for the relies lads.
Ive got the cam pointers set up, its got a new phase sensor gapped proplerly and a CPS also gapped. I may have inadverently moved something else, i will check tomorrow. I tried putting the kinglead to a good earth point but there was nothing at all when i turned the engine over?????
Back to scratching me head unfortunalty. (i got a spark yesterday before i moved the dizzy!!??)
Thanks guys
Muffster.
Old Mar 18, 2007 | 05:45 PM
muffster's Avatar
muffster
Hello again
im not sure where my problem lies but is it possible to test the input and output of the coil with a multimeter? ive tried putting the kinglead against the body and got nothing. Where would i go back to from the coil, does it run from a fuse or a relay?
Thanks a lot.
Muffster.
Old Mar 20, 2007 | 10:23 AM
muffster's Avatar
muffster
Default cossie not starting
Any offers please guys.
Ive got no spark coming out of my coil, so where is the next place to look.
Thanks
muffster.
Old Mar 20, 2007 | 12:11 PM
pacman's Avatar
pacman
don't know whether its related had same type of problem with mine couple of years back and eventually traced it back to the immobiliser on the alarm that was fitted
Old Mar 20, 2007 | 01:48 PM
muffster's Avatar
muffster
Hi mate.
I thought about the alarm and immobiliser but up until a few days ago i was getting a spark so now im confused and dont know where to go next!
Muffster
Old Mar 20, 2007 | 10:45 PM
davidreader5's Avatar
davidreader5
Default no spark
Hi,
The phase sensor has no effect on ignition timing,
you must have a crank sensor, coil, amp, wiring fault, or ecu,fault.
i have sent you a pm to test amp,inc coil,etc.
Dave R.
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
