4x4 cos, brake problems...
Old Mar 16, 2007 | 08:24 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Default 4x4 cos, brake problems...
Right, my brake pedal started to go a little spongy, needing about an inch of travel or so before the brakes would come on. Once past there, braking was fine and the pedal would get progressively harder until I left it for a while, at which point the spongyness would come back.
So, I decided to bleed the whole system and replace with new fluid, hoping that maybe it was a little air/water in the fluid.
Now, the pedal feels just fine, car brakes perfect so the fluid replacement was worthwhile
But, and it's a big but.... the abs light is permanently on, along with the handbrake light
Took the car for a little spin and she brakes just fine
Searched on here, and looked at posts I had bookmarked, but can't figure out what could be wrong.
I didn't leave the pump on for ages while bleeding, so I would be surprised if I had burned it out, any other ideas ?
Old Mar 16, 2007 | 08:32 PM
trevCOSS's Avatar
trevCOSS
didnt forget to plug the resovoir sensor back in did you?
Old Mar 16, 2007 | 11:42 PM
frog's Avatar
frog
No, definitely back on
Old Mar 17, 2007 | 07:42 AM
Alvyn's Avatar
Alvyn
top the brake fluid up in the master!
Old Mar 17, 2007 | 08:37 AM
I have to keep the fluid level about 1" ABOVE the MAXIMUM mark otherwise I too get this, obviously the float inside the m/cyl is a little overcautious.
Old Mar 17, 2007 | 10:19 AM
frog's Avatar
frog
Fluid is above MAX already, I'll try and put a little more in then .
Wish me luck
Old Mar 17, 2007 | 12:00 PM
frog's Avatar
frog
More fluid sorted it out.
Well. after I realised I needed to take the handbrake off for the light to go out
Thanks chaps
Old Mar 17, 2007 | 03:20 PM
Thanks chaps
Doh!
`spotty
Sep 25, 2015 11:41 PM
IainRS1700T
Sep 25, 2015 06:44 AM
coscor86
Sep 20, 2015 01:21 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
