Custom brake rotors?
Old Mar 8, 2007 | 10:52 PM
sunny scott's Avatar
sunny scott
Default Custom brake rotors?
Anyone know any places in Scotland that will make custom brake rotors.
Time to replace the rotors on mine but Godspeed want £300 just for the rotor and new bolts to fit to the existing bell. Hoped i might be able to get them cheaper than that. Might even end up replacing the bell's too as think
Godspeed are the only company to use 10 mounting holes, AP and Willwood use 8.
Old Mar 9, 2007 | 08:36 AM
cos47's Avatar
cos47
Not in Scotland but try A1 Rallysport mate 01767-691617
Old Mar 9, 2007 | 12:36 PM
Wilwood use 8 10 & 12 mounting holes, what size disc do you need ?
Hi spec only cut the bell part of a normal cast disc that you can buy down local motor factors, I have been there when they have done it.
let me know what size discs they are and i will find you some.
Failing that just buy some of the right size and have the bells cut off and holes drilled.
Old Mar 9, 2007 | 04:06 PM
sunny scott
It's a 290mm disc braking surface goes down to 188mm and center is 150mm, 21mm thick. never thought about cutting off other discs, Thanks for that, i might give that a go.
Old Mar 9, 2007 | 06:23 PM
Can't find this dimension readily available in my catalogues.
I would phone up EBC get a catalogue and do a lot or searching, or get down to local motor factors and ask to search through some discs for suitable donor ones to cut off the bells.
Take your existing bells with you to see if a good fit.
