Battery question/light
Old Mar 6, 2007 | 04:52 PM
rabmc's Avatar
rabmc
Default Battery question/light
Right got my car back on road there , now fitted a new alternator and bought a new battery also , now my greif is , now dont know if this is a problem now when i turn key to start car my battery light stays on and battery voltage is just above 12volts with engine running , now i give it a bit of throttle light goes out and shoots up to way over 13volts think about 13.9 roughly anyway its annoying me lol
Now the main one is when out at night , if i brake or put window up or down i can see my battery light slightly glowing faintly , and can see it glowing most of the time at night but more so when i do the above , why is this and is it anything to worry about , dont want my battery going flat etc
Thanks
Old Mar 6, 2007 | 05:07 PM
iansoutham's Avatar
iansoutham
OCD Victim
Do a volt-check @ the alternator itself, as it could be the leads breaking down, or the alternator could have shat itself.
If the volts stay low until reved, then either the blue ind. wire is not connected, or the diode pack is shot.
Old Mar 6, 2007 | 05:10 PM
rapidcossie's Avatar
rapidcossie
Rab....remove the blue wire to back of alty and replace the boot type connection....i had a very similar problem and found that there were only a few strands of this wire left but took ages to find prob as it was inside the rubber boot....
Old Mar 6, 2007 | 05:20 PM
rabmc's Avatar
rabmc
Cool will thy that , its a pain in the aRSe this niggly shit , this blue wire what will be happening or not if its broken or not working
Where does this blue wire trace back to ? does it get a voltage from the aprenator etc
Old Mar 6, 2007 | 05:26 PM
rapidcossie
the whole charging system will not work without the blue wire mate.
it comes from behind the light on the dash i think.
the system is simple enough mate.
Old Mar 6, 2007 | 05:42 PM
rabmc's Avatar
rabmc
Cool got new clocks to go in anyway , al have apart tomorrow and take a look dam wire how can the whole charging system be controlled by one wire which is such a awful colour
Old Mar 6, 2007 | 06:42 PM
iansoutham's Avatar
iansoutham
OCD Victim
It will work without the blue wire, the charge circuit will "self generate" until it exceeds the diode capacity, and the diode pack "leaks" current past. This normally happens about 2k rpm.
The ind. wire simply makes this an automatic circuit control.
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
