Misfire on startup
Old Mar 4, 2007 | 06:22 PM
Karl 3dr's Avatar
Karl 3dr
Default Misfire on startup
My 2wd sapphire has a misfire when first started, hot or cold, the spec is as follows, long studded 200 block (new), wrc h/gasket, the head has been skimmed and pressure tested, std head and cams, t38, grey injectors, grp a coil, fort motorsport leads, motorcraft AGPS071c plugs, peaks at 30psi, drops back to 28psi,
new engine loom etc. It runs fine when the misfire has cleared and goes really well on boost etc but this misfire's p'ing me off to say the least!
Has any one else had any similar problems or suggestions as to what it may be? What plug gap's would anyone recommend?
Any help appreciated!
Old Mar 4, 2007 | 07:01 PM
Alvyn's Avatar
Alvyn
check for an air leak from inlet manifold
Old Mar 4, 2007 | 07:24 PM
Karl 3dr's Avatar
Karl 3dr
hi mate, thanks for the input, already checked for air leaks, engine's done approx 2500 miles and all new cometic gaskets fitted.
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
