Worn Turbo
Old Mar 2, 2007 | 02:05 PM
ASHCOSSIE's Avatar
ASHCOSSIE
Default Worn Turbo
On my mates series 2 the oil cap keeps getting blown off, his turbo is now taking longer to spin up and when it does you can't notice the power from the turbo, would a worn turbo build up pressure through the oil return pipe to cause the cap to come off or could it be something else.
thanks
Ash
Old Mar 2, 2007 | 08:45 PM
fast_ford_uk's Avatar
fast_ford_uk
possible but more likely that his breather system is blocked, has he got a boost gauge fitted, the acuator could be wanked
Old Mar 3, 2007 | 07:26 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Sounds like a tired engine to me, do a compression check on all cylinders, hot and cold and post the results and we will tell you more
Bri.
Old Mar 4, 2007 | 09:55 AM
DENNIS's Avatar
DENNIS
you have excessive crank case pressures , if its a tuned car fit a breather system, would be wise to check compression's ( dry & wet ? poss rings.) or preferably a cyl leak off test.
most likely the extra lag could be down to this....
Marino
Sep 12, 2015 11:10 AM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
