No Gears!!!
Old Feb 27, 2007 | 01:03 PM
cossie04's Avatar
cossie04
Default No Gears!!!
Hi peeps, I took my car out last night and did about 15 miles (addmitely, with a lead foot all the way), and i pulled up, switched off. Fine . Got back in 5 mins later, put it in first, pulled off about 5 ft and then felt a light fud from the gearbox area and all gears gone.
Any ideas? Clutch?, Gearbox?
Any info much appreciated as my car is stuck on the driveway being a melon .
Sorry, forgot to mention the fact that it is a Mondeo ST200 on a V plate.
Old Feb 27, 2007 | 01:50 PM
SafeChav's Avatar
SafeChav
Try and put it in reverse without using the clutch, if it crunches the box has probably shit itself, if it doesnt probably the clutch.
Old Feb 27, 2007 | 01:58 PM
cossie04's Avatar
cossie04
Thanx for that. Tried it, dosen`t crunch. Just wont go in without the clutch.
Anyone ever done a clutch on one of these?, for some reason me thinks it won`t be quite so simple.....
Old Feb 27, 2007 | 02:06 PM
SafeChav's Avatar
SafeChav
Ah........maybe its got a synchro on reverse then being a newer car.
Well.......if it wont go in gear without the clutch, that shows the clutch is working!
My money is on the box mate
Old Feb 27, 2007 | 02:08 PM
cossie04's Avatar
cossie04
Old Feb 27, 2007 | 02:11 PM
SafeChav's Avatar
SafeChav
My thoughts exactly
Old Feb 27, 2007 | 02:13 PM
cossie04's Avatar
cossie04
Any ideas how much i`m looking at for a rebuilt / second-hand gearbox?
Old Feb 27, 2007 | 02:14 PM
SafeChav's Avatar
SafeChav
Not a clue mate
I suppose there is still the slimmest of slim chances the clutch has gone, after all it takes no effort to spin the input shaft, but obviously a lot of effort to move the car.
Are you going to fit it yourself?
Old Feb 27, 2007 | 02:16 PM
cossie04's Avatar
cossie04
I was thinkin about it...
Old Feb 27, 2007 | 02:17 PM
SafeChav's Avatar
SafeChav
Well either way..........gearbox or clutch, the box has to come out...........then you can get a definate answer
Old Feb 27, 2007 | 02:19 PM
cossie04's Avatar
cossie04
Best get cracking then!! Cheers for that mate....
Old Feb 27, 2007 | 02:21 PM
SafeChav's Avatar
SafeChav
You have fun yea
Old Feb 27, 2007 | 02:58 PM
Paulo P's Avatar
Paulo P
What happens if you put it in gear and try and start it?
Old Feb 27, 2007 | 03:12 PM
SafeChav's Avatar
SafeChav
thats going to be the same story though, you still cant tell if its the clutch or box thats broken
Old Feb 27, 2007 | 03:51 PM
eliters1's Avatar
eliters1
if it was clutch it would not go in regarless of pedal as it still being driven and box is offering some resistance as wont go in without clutch so id look at driveshafts cvs etc,does your speedo go up with it in say 2nd gear revving?
Old Feb 27, 2007 | 04:03 PM
SafeChav's Avatar
SafeChav
If the clutch plate has shat all its friction material then you wont get any drive on the input shaft with it in gear, it will be metal on metal, flywheel/pressure plate on the rivets on the clutch plate.
Old Feb 28, 2007 | 07:46 AM
eliters1's Avatar
eliters1
but does the speedo still move,also what i meant was that normally if the clutch has totally gone it should go into gear with out pressing it down as thiers nothing to release ie no drive so the box should go in to gear without it,my old vr6 did this and could put in gear with no clutch and rev it on the spot.if the speedo moves the box is being driven hence not clutch as its moving inside the box to drive it but if its not then yeah prob is clutch but as safechav said best to strip it out and see.
Old Feb 28, 2007 | 11:41 AM
SafeChav's Avatar
SafeChav
The speedo wont move if the diff has fallen apart. I know what you are saying about the clutch, i said the same thing hence why i told him to try and select a gear................and being as it wouldnt go in without the clutch i said i'd say the box was shot............
Old Feb 28, 2007 | 12:57 PM
eliters1's Avatar
eliters1
see what you mean,as the clutch is workin so must be the box,would find if a d shaft on the way out with the box anyhow,but like you say know ing a fwd ford,prob the diff gone
Old Mar 1, 2007 | 10:07 PM
cossie04's Avatar
cossie04
Does anyone know if a mrk 1 24v box will fit mine?
Old Mar 4, 2007 | 03:32 PM
SafeChav's Avatar
SafeChav
cant help you there mate, out of my territory
tankybaby66
Feb 6, 2016 02:24 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
cameron2
Sep 23, 2015 06:31 PM
