help plz
Old Feb 23, 2007 | 05:00 PM
330bhpcoz's Avatar
330bhpcoz
Default help plz
if i had changed a gearbox ,would a gearbox by any means stop the starter from turning the car over,? cheers oh yeh even it was all bolted up rite
Old Feb 23, 2007 | 06:11 PM
gup's Avatar
gup
did the main shaft go in the flywheel alright what does the clucth pedal feel like also did you check your clut6ch on the new g/b
Old Feb 23, 2007 | 06:37 PM
330bhpcoz's Avatar
330bhpcoz
it was my old clutch wich was spot on ,as for the shaft ,the box looked bolted on good and tight,and also the starter has stoped turning the car it only spins
Old Feb 23, 2007 | 06:39 PM
330bhpcoz's Avatar
330bhpcoz
the starter has stoped turning the car it only spins ,and b4 it was fine it driving me nuts
Old Feb 23, 2007 | 09:21 PM
330bhpcoz's Avatar
330bhpcoz
ANY HELP WOULD BE GOOD
Old Feb 23, 2007 | 09:31 PM
SafeChav's Avatar
SafeChav
Did you connect the main starter cables up, i know it sounds dumb but its worth asking.
Old Feb 23, 2007 | 09:59 PM
330bhpcoz's Avatar
330bhpcoz
theres only two i trust
Old Feb 23, 2007 | 10:23 PM
SafeChav's Avatar
SafeChav
Well usually 3, one from the alternator, the thick one from the battery, and the small thin wire for the solenoid.
Old Feb 23, 2007 | 11:35 PM
330bhpcoz's Avatar
330bhpcoz
ur rite ,but would that get troubled if removing gearbox
Old Feb 23, 2007 | 11:41 PM
SafeChav's Avatar
SafeChav
What car is it on? Most cars the starter is on the gearbox so i would say so!
Old Feb 24, 2007 | 07:52 AM
330bhpcoz's Avatar
330bhpcoz
ye on the gearbox ,but would changing a gearbox stop ther starter from starting
Old Feb 24, 2007 | 11:39 AM
SafeChav's Avatar
SafeChav
Depends what you mean by stopping the starter starting?
Does the starter work at all???
Old Feb 24, 2007 | 06:04 PM
330bhpcoz's Avatar
330bhpcoz
it works but only spins does not start the car makes like a weeeeeeee noise and thats it
Old Feb 24, 2007 | 06:16 PM
SafeChav's Avatar
SafeChav
Fuck knows! Sounds like its not engaging then! Are they easy to whip back off on them? Or a bit of mashing with a hammer help
Old Feb 28, 2007 | 08:35 AM
330bhpcoz's Avatar
330bhpcoz
they more or less just pop out 3 bolts to the box
Old Feb 28, 2007 | 11:40 AM
SafeChav's Avatar
SafeChav
Whip it out and check to see if its engaging, im guessing its not.
Old Mar 1, 2007 | 02:50 PM
330bhpcoz's Avatar
330bhpcoz
how would you do that
Old Mar 1, 2007 | 02:52 PM
SafeChav's Avatar
SafeChav
The gear on the starter slides to engage witht he flywheel ring gear, check its not ceased or damaged!
Old Mar 1, 2007 | 04:02 PM
antony215's Avatar
antony215
Escort Rs Turbo
Unbolt it but leave all the wiring connected and get someone to turn the ignition key you will soon know if it's engaging you will see the small wheel come forward and spin (really fucking fast ) if it dont come forward then your stater is fucked .
Old Mar 1, 2007 | 04:31 PM
SafeChav's Avatar
SafeChav
you never give the proper technique for testing things.
Your meant to stick your finger in and check the gear spins strongly
Old Mar 1, 2007 | 05:24 PM
antony215's Avatar
antony215
Escort Rs Turbo
Old Mar 1, 2007 | 08:13 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Sounds like the solenoid is either goosed or there is a break i n the wire going to it, as said if its not engaging then you can replace just the solenoid I paid £7 for a new one for me old S2
Bri.
rsturbo27
Sep 1, 2015 09:54 PM
niallturbo
Dec 21, 2004 08:14 PM
cossieanth
Nov 21, 2004 06:54 PM
11
Mar 13, 2004 09:11 AM
28
Dec 10, 2003 07:46 PM
