misfire on startup?
Old Feb 22, 2007 | 06:01 PM
sjm's Avatar
sjm
Default misfire on startup?
anybody any idea's on what makes a cossie misfire on startup for about a minute. soon as it starts to warm it clears. it only does it when its cold, ie. when you fire it up first thing in the morning. it does'nt do it if its warm and once up to good running temp it does'nt do it at all, no misfire all through the rev range.
Old Feb 22, 2007 | 06:10 PM
SafeChav's Avatar
SafeChav
Possibly fouled up plugs?
Old Feb 22, 2007 | 06:24 PM
Crappy ford coil, mine did it until I used a group a.
Did it even with new MAGNECOR LEADS new AGPR12PP8 plugs as well, does not miss a beat with group a coil.
Better running idling more low down power massively better starting.
Old Feb 22, 2007 | 07:10 PM
dave green's Avatar
dave green
Head gasket ?
Dave
Old Feb 23, 2007 | 08:09 AM
sjm's Avatar
sjm
i'm already running a group a coil, i not using oil or water and they are both still clean.
Old Feb 23, 2007 | 05:27 PM
Check your CO, and if ok clean your ISCV, these play up more when cold, and can and do cause misfires.
The ISCV does not do just idle, it controls all off boost below 1800rpm.
Old Feb 23, 2007 | 08:26 PM
G60's Avatar
G60
take the plugs out and check for water sitting on the piston, My friends 3 door was exactly the same and once ran for a while the water clears and all is o.k.
Hopefully not the case but worth checking.
G60
Old Feb 24, 2007 | 07:35 AM
sjm's Avatar
sjm
i pulled the plugs out last night, the electrodes look the right colour but they are a bit sooty, so i would say its slighty rich. i'll take them to be cleaned along with the iscv.
whilst there out i'll look down top and see if i can see any puddles. would it be worth doing a compression test, and if so what sort of pressure should i see, (std 200 block).
Old Feb 24, 2007 | 09:31 AM
sjm's Avatar
sjm
plugs like new, iscv like new and the tops of the pistons were dry.
still did it just not as bad.
any more ideas??
Old Feb 28, 2007 | 05:17 PM
Karl 3dr's Avatar
Karl 3dr
Mine does the same, really gets on my tits! I'm wondering wether it could be coolant temp sensor or air temp sensor?
Old Feb 28, 2007 | 07:48 PM
Wardy257's Avatar
Wardy257
Disconect the CTS and see if it is better.
j.hammond1
30
Oct 31, 2021 05:28 PM
Brickhouse
Sep 21, 2015 11:00 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
taylora1409
Aug 12, 2015 12:06 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
