Car alarm probs.....
Old Sep 9, 2004 | 08:37 PM
smudgerz's Avatar
smudgerz
Default Car alarm probs.....
Hi all, got a problem with me car alarm. It keeps going off at randam times, could a shaged battery be the cause? I have turned the senceativity bit down but it was no help. Any help would be great, as im not flavour of the month with the neighbours!!!!!!!!!!!!!!!!
Old Sep 9, 2004 | 10:06 PM
MikeyXR2i's Avatar
MikeyXR2i
what make m8?
Old Sep 10, 2004 | 12:50 PM
smudgerz's Avatar
smudgerz
Mikey, its a cliford concept 300, not been fitted that long ether
Old Sep 10, 2004 | 12:54 PM
MikeyXR2i's Avatar
MikeyXR2i
oh i see, i got a laserline on the S1, mines was false alarimg as stupid times when it put away, it was a dicky bonnet switch.
Old Sep 10, 2004 | 01:39 PM
Dave Henshall's Avatar
Dave Henshall
bonnet switches are always favouritr on cliffordds, the clifford bonnet switch is on open type which allows water and grime into the contact very easilly.
Old Sep 10, 2004 | 02:03 PM
smudgerz's Avatar
smudgerz
Cheers Dave will go and have a look at it now.
Old Sep 10, 2004 | 04:04 PM
sm's Avatar
sm
its typical problem with a clifford alarm its not the actual alarm but the way the fitter installed it, ur best bet is check everything as its not unheard of for wires not to be soldered, the black box not bein secured to the bulkhead behind the dash properly and a few other things many peeps have had this on here all because the installer rushes the fittin so he can move onto the next car
cheers kev
Old Sep 10, 2004 | 06:20 PM
smudgerz's Avatar
smudgerz
Cheers Kev, if the problem a'nt sorted with a new battery and a clean of the bonnet sencer, then i will get it serviced by a dealer and have all the faults checked, bit peed off cause it only got fitted in April
Old Sep 10, 2004 | 06:59 PM
Dave Henshall
the concept 300 does have evet recall, (sens and tell) so you can interogate it as to what casued the alarm, just remembering back, my concept 600 had a2 new bonnet switches but when the autostart was armed and then you shut the door it would disarm and not start - the sens and tell indicated that it was the bonnet switch , which had already been replaced - turned out to be where they had run the wire through the bulkhhead as sm says, (they rush) they hadn't fitted a grommet and it had fridged throughthe insulation of the cable and it was only when slamming a door it caused it move enough to earth out. another one to check anyway.
Old Sep 11, 2004 | 09:09 AM
smudgerz's Avatar
smudgerz
Cheers Dave, will check it out.
Old Jun 16, 2009 | 05:12 PM
moesin2005's Avatar
moesin2005
mine keeps doin this but there is no bonnet switch or is it because it is missing
Old Jun 16, 2009 | 05:31 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
moisture ingress into any of the door/bonnet/boot switches is quite common
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
kosienutter
31
Aug 22, 2015 09:55 AM
adriansaleem
Aug 3, 2015 11:21 AM
