ABS not working properly!!!!
Old Sep 9, 2004 | 06:08 PM
rog's Avatar
rog
Default ABS not working properly!!!!
I have a 4x4 sapph, the abs light comes on when i start the car, which it's supposed to do i believe, then it goes off.
But sometimes when i go to drive away the ABS comes on and the brakes don't work, the pedal judders like the abs has cut in, but when i reach over 20moh, the light comes on and the brakes work ok again.
Sorry if that doesn't make much sense but has this happened to anyone else here before?
Rog.
Old Sep 10, 2004 | 11:49 AM
rog's Avatar
rog
BTTT
Old Sep 10, 2004 | 12:10 PM
wimwerf's Avatar
wimwerf
i have this to. when im braking soft the abs cuts in. but when i brake hard its ok.
a bloke told me once that it could be the wires which are connected to the hubs (spelling).
cheers
Old Sep 10, 2004 | 12:15 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
It's a common problem m8, could be a faulty hub sensor, bad electrical connection or a problem with the ABS unit itself.
Maybe best try someone else's ABS unit first if you can, otherwise, change sensors. I believe (really not sure on that one), that they are the same as on Granadas which may be cheaper than buying ones for a cossie (or, more easily available from a breaker's yard).
If changing sensors didn't help, you have a wiring problem.
good luck.
Old Sep 10, 2004 | 12:50 PM
RS500/364's Avatar
RS500/364
sensor if you got 1 from the breakers check it on a good system then put it on yours and swap around the 1 you take off start with the n/s/f main one that goes and the back ones are diffent
Old Sep 10, 2004 | 04:34 PM
bob s2zvh's Avatar
bob s2zvh
i should have spare ones for you when i get home!
Old Sep 11, 2004 | 01:39 PM
rocar's Avatar
rocar
Disconnect the sensor plug and check resistance with a multimeter you should not have continuity repeat as per four ,clean all four plug connections after check.
Roger
Old Sep 11, 2004 | 07:05 PM
Nick500's Avatar
Nick500
4x4's have a different ABS module Bob, I have one from BNO if you are really stuck rog!
Nick
original
Apr 28, 2026 05:20 PM
moesin2005
Jan 23, 2022 06:28 PM
rdvil
Aug 15, 2015 12:11 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
