steam cleaning.........
Old Sep 8, 2004 | 08:34 PM
smudgerz's Avatar
smudgerz
Default steam cleaning.........
Hi all, ive got a small oil leak on my 2wd cossie. The engine is a bit mucky so need to clean to try and find leak. Is it ok to steam clean me engine? is there any stuff that needs to be covered?
Thanks in advance!!!
Smudge.
Old Sep 8, 2004 | 09:10 PM
swerv's Avatar
swerv
just stay away from ignition system and try not to direct the steam at electrical connections, you should be alright then
Old Sep 8, 2004 | 09:13 PM
b13nde's Avatar
b13nde
ive found it to be ok just try and keep away from the throttle postion switch on the side of the throttle buterfly other wise the dam thing just keeps revving up by its self up to 3500 rpm a pain ignition sys is ok just wipe out the water
Old Sep 9, 2004 | 06:30 AM
dave green's Avatar
dave green
As above. but underneath will be ok
Old Sep 9, 2004 | 08:32 PM
smudgerz's Avatar
smudgerz
Thanks for the reply's, hopefully now i will find this pesky oil leak, Smudger.
Old Sep 10, 2004 | 09:51 AM
sm's Avatar
sm
if u got an alarm siren then unbolt it and wrap it up in cling film as u dont want water gettin in it and start givin u problems
cheers kev
Old Sep 10, 2004 | 12:49 PM
smudgerz's Avatar
smudgerz
Cheers sm, got enough hassel with me alarm........
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
skypeller
Sep 19, 2015 09:58 PM
M7 COS
Jul 26, 2005 06:56 PM
pugo
13
May 5, 2005 02:33 AM
abdr500
Dec 29, 2004 04:45 PM
