Rocker Cover Gasket...Sealant. Whats best???
Old 08-09-2004 | 02:59 PM
CosRush's Avatar
CosRush
Default Rocker Cover Gasket...Sealant. Whats best???
I hvae had my Rocker cover off a cople of times now and each time when its back it leaks around the half moon seals.
Can anyone recommend a good sealant to use as well?
Old 08-09-2004 | 03:02 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Blue hylomar, works fine for me, been told it disolves well in oil which is good if some of it ends up in your oilways...
Old 08-09-2004 | 04:45 PM
CosRush's Avatar
CosRush
Thanks Mate, i'll try that
Old 08-09-2004 | 04:51 PM
frog's Avatar
frog
No worries, just dip the ends of the half moon in the tube, much easier than trying to get a blob of sealant in the right spot without making a mess of it.
Old 12-09-2004 | 07:29 PM
blaazer2's Avatar
blaazer2
hylomar does not dissolve it clogs pickup pipes ,use wellseal or high molecular silicone ,many car manufacturers do not use gaskets today instead they use silicone sealant when built in the factory from new!!!!
Mark RS
05-03-2021 06:08 PM
fordrallycar
30-09-2015 07:57 PM
Fil
30-09-2015 12:08 PM
deathrider666
28-09-2015 06:12 PM
Quick Reply: Rocker Cover Gasket...Sealant. Whats best???
