acceleration probs
Old Sep 7, 2004 | 09:50 PM
foggie_2's Avatar
foggie_2
Default acceleration probs
Ello all, i have a 1989 sapphire cossie, its had loadsa mods done to it ect ect, but recently ive noticed i cant seem to accelerate over 4000rpm in 2nd 3rd and 4th, it accelerates like a bat outta hell, then soon as it gets to 4000rpm nothing!!! can anybody help me (please) THANX
Old Sep 11, 2004 | 12:53 AM
SS1's Avatar
SS1
i had this problem with a d reg chipped rs s2
the hoses samco air hoses where
collapsing on high revs
might be worth a try took i it to a tuner
in warrington and cringed as he reved
the fook out of it standing still.. the main
induction hose collapsed car just died
Old Sep 11, 2004 | 06:06 PM
foggie_2's Avatar
foggie_2
nice 1 cheers 4 dat
Old Sep 11, 2004 | 07:19 PM
blaazer2's Avatar
blaazer2
what does your boost gauge tell you at 3750 rpm and what does it read at 4100?
Old Sep 11, 2004 | 11:44 PM
velocity's Avatar
velocity
check if a p8 ecu (escort coz type) was fitted with all the mods.if so then you have a sensor failure,p8 ecu,s restrict engine revs to 4000 rpm or there abouts for sensor failures,
Old Sep 12, 2004 | 03:18 PM
foggie_2's Avatar
foggie_2
cheers guys 4 replyin, gonna check my boost now, cheers again!
Old Sep 12, 2004 | 06:12 PM
foggie_2's Avatar
foggie_2
I checked the boost, at 3750 its 10psi and at 4100 its 20psi, also i found out exactly what was done to the engine b4 i bought it, multilayer steel headgaset, big escort turbo,-31 actuator,k&n filter, stage 3 superchip, mongoose exhaust,dark green 803 injectors, 3bar map sensor,alloy rs500 intercooler, 0.05 mahle pistons, cheeRS
Old Sep 18, 2004 | 09:46 PM
foggie_2's Avatar
foggie_2
plz help anybody!!
Old Sep 19, 2004 | 12:05 AM
Dave McB's Avatar
Dave McB
check there aint a prob or leak with the wastegate/actuator cos i had similar proba and the exhust housing was fooked
Old Sep 19, 2004 | 02:09 PM
foggie_2's Avatar
foggie_2
how do you check if theres a problem or a leak in the wastegate/actuator ?
Old Sep 22, 2004 | 05:57 PM
ASHCOSSIE's Avatar
ASHCOSSIE
WHAT ABOUT PLUG GAPS
Old Sep 22, 2004 | 07:29 PM
b13nde's Avatar
b13nde
check the cornections to the amal valve just make sure there on ok i had them playing around on me
gcfcos
59
Oct 6, 2015 05:04 PM
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
landaqmabba
Sep 15, 2015 07:16 PM
Marino
Sep 12, 2015 11:10 AM
