Piston movement
Old Feb 2, 2007 | 10:02 PM
  #41
khanny's Avatar
khanny
YE FORGOT ALL ABOUT IT IL AV A GO NOW,. WHAT YOU MEAN MSN BUTTON M8?
Old Feb 2, 2007 | 10:04 PM
  #42
SafeChav's Avatar
SafeChav
safechav@hotmail.com
but theres a button below my siggy sayin MSN
Old Feb 2, 2007 | 10:36 PM
  #43
SafeChav's Avatar
SafeChav
Got your pictures
ok.....its got the CPS fitted to it. What flywheel is that on there, doesn't look familiar
Old Feb 2, 2007 | 10:42 PM
  #44
khanny's Avatar
khanny
NOT SURE BUT TOOK THE OUTER 1 OF THATS IN THE PIC ON THE FLOOR LOOKS A BIT LIKE A CLUTCH SPRING PLATE OR SOMET I HAVE NO CLUE TO BE HONEST M8 NO EXPERIENCE WITH TURBOS AT ALL AS YOU CAN TELL BUT A FAIR BIT WITH XR3S AND 3I XR2 ECT
Old Feb 2, 2007 | 10:44 PM
  #45
SafeChav's Avatar
SafeChav
The flywheels and clutches are exactly the same as the 32's and 2i's mate.
The only difference with the fiesta turbo flywheel (and EFI 3i's and 2i's) they have notches on the back which the crank sensor reads.
Is the flywheel on it now the one it came with?
Old Feb 2, 2007 | 10:45 PM
  #46
khanny's Avatar
khanny
YE M8 THATS THE FEZZY BOTTOM AND FEZZY FLYWHEEL THAT CAME WITH IT THE PIC OF THE 1 ON THE FLOOR WAS BOLTED ON TOP OF THE FLYWHEEL BOLTS ALL THE WAY ROUND THE OUTER EDGE
Old Feb 2, 2007 | 10:51 PM
  #47
SafeChav's Avatar
SafeChav
just zoomed them up the flywheel looks familiar actually.
Check to see if it has the timing marks on the back where the sensor reads.
Old Feb 2, 2007 | 10:53 PM
  #48
khanny's Avatar
khanny
DO I NEED TO TAKE IT OF TO DO THAT, SENT YOYU SOME PICS OF THE CAR AS WELL WHAT YOU RECKON I NEVER BUTCHED THE FRONT BUMPER THO
Old Feb 2, 2007 | 10:59 PM
  #49
SafeChav's Avatar
SafeChav
You should be able to see without taking them off, if you compare it to you old flywheel you will soon be able to tell if it has
Old Feb 5, 2007 | 07:54 PM
  #50
khanny's Avatar
khanny
HI M8 GOT THE BOTTOM END ON NOW YOU DEFONATLY SHAW I WONT HAVE ANY TROUBLE WITH THAT FIESTA FLYWHEEL BEING KEPT ON,, I DONT WANT TO REBUILD IT ALL JUST TO HAVE TO TAKLE IT ASLL APART AGAIN CHEERS
Old Feb 5, 2007 | 08:02 PM
  #51
antony215's Avatar
antony215
Escort Rs Turbo
Fiesta one will be fine the only difference with the fiesta one is it has the marks on the back for the CPS otherwise there exactly the same
Old Feb 5, 2007 | 08:24 PM
  #52
Karlos G's Avatar
Karlos G
Balls Deep!
Whats the advantage of going EFi then??
Karlos
Old Feb 5, 2007 | 08:57 PM
  #53
khanny's Avatar
khanny
SO THE MARKINGS ON THE BACK IS THERE ANYTHING I NEED TO SET THEM UP 4 THEM 2 WORK IN OTHER WORDS WHY DO THE FEZZY 1NS HAVE THEM AND THE SCORT NOT CHEERS
Old Feb 5, 2007 | 09:35 PM
  #54
antony215's Avatar
antony215
Escort Rs Turbo
No
Because the fiesta uses EFI management and the escort dont
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
ajamesc
Sep 8, 2015 06:51 PM
rsturbo27
Sep 5, 2015 05:08 PM
