Cossy ECU identity
Old Sep 6, 2004 | 09:15 PM
2ndGear's Avatar
2ndGear
Default Cossy ECU identity
Can anyone help with identifing the ecu i have, on the side of it says IAW 048/01 and on the other 0502. There is also a sticker on the front that read s Weber. IAW 048/01 then the following - WD48.08/L3H.93 -
When i have removed the lid there is a piggy back board fitted.
Any help would be great.....
Old Sep 6, 2004 | 11:32 PM
Stu @ M Developments's Avatar
PassionFords Creator
It is a Level 8 Sierra 4x4 ecu.
Old Sep 7, 2004 | 07:38 PM
richm's Avatar
richm
late type Green-top for Catalyst equipped car with lambda sensor... If it's standard and original, the chip in the piggyback board should have L3H93 on the label too.
Old Sep 7, 2004 | 08:16 PM
velocity's Avatar
velocity
whats this one IAW 048/02 WD48.08/L3H.34 its in my 92 sapph 4x4 green top (the catalyst off which has been binned a long time ago) but it dont match the numbers above
Old Sep 7, 2004 | 08:39 PM
richm's Avatar
richm
velocity,
That is a for a <92 red-top, pre-catalyst non-lambda application
Rich
Old Sep 8, 2004 | 02:09 PM
velocity's Avatar
velocity
is it a level 8 please please
Old Sep 8, 2004 | 02:17 PM
wimwerf's Avatar
wimwerf
every 4wd saph has L8 as standard.
Old Sep 8, 2004 | 02:53 PM
Dave Henshall's Avatar
Dave Henshall
it is a level 8, yes.
Old Sep 8, 2004 | 03:51 PM
velocity's Avatar
velocity
thanks lads just needed to be sure
Old Sep 9, 2004 | 07:57 AM
alan rainbow's Avatar
alan rainbow
can the red top l8 be used for closed loop control
come on stu
Yes pal.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
