charcooler intercooler i dont know
Old Jan 19, 2007 | 04:50 PM
zippyka80's Avatar
zippyka80
Default charcooler intercooler i dont know
hi i am building a 2.0 zvh converted ka withe a stage 3 rs head 2.0 bottom end and a standard t3 turbo off a rs turbo i have got to have a one off rad but i was wondering wat a charge cooler was is it like a intercooler but uses water to cool instead im only asking as i think it may be better for me as space is tight
Old Jan 19, 2007 | 04:52 PM
SafeChav's Avatar
SafeChav
From what i know of charge coolers they aren't very good if you wan't to give the car a long run thrashing it, they build up a lot of heat and need some normal driving to allow temperatures to drop again.
Plus ive heard a lot of stories about charge coolers splitting internally which = water in your engine which = rebuild please
Old Jan 19, 2007 | 08:22 PM
AustenW's Avatar
AustenW
Get a proper chargecooler system and you will not have a problem.
The problem with the pace set up which is what everyone judges chargecoolers by is that they use inefficient cores, small pre-rads and a tiny water pump.
When speced properly my set up always ran 10 deg above ambient at 24psi from my data logging
Simon Norris with the Evo has fitted a PWR chargecooler for this year so what does that tell you?
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
