sapphire cossie misfire?
Old Jan 19, 2007 | 09:03 AM
spmotorsport's Avatar
spmotorsport
Default sapphire cossie misfire?
hello there.
have recently bought a 1990 ford sapphire cossie 4x4 and am having a ball in it, only problem that i have with it is that when i go full boost or when i am behind some dick goin 5km down the main street of town the car develops a major misfire, the revs go crazy (like the throttle open a little bit, hovers around 3,000rpm) and when i go full boost it will try and launch me out the windscreen, which is really not a good way to get out of ya car, came to a climax a couple of weeks ago when the car stuttered like hell then died, sat on side of road cranking car for a good minute or two, with foot hard on the firewall, it was coughfing like an old man then fired into life with a bang and flames comin out exhaust, then drove fine, have asked a few fellow cossie owners if they had same problem, one guy said he did but went to stage 2 and it went away, any help would be great
cheers hadyn bruce
tauranga new zealand
Old Jan 19, 2007 | 02:24 PM
trevCOSS's Avatar
trevCOSS
sensor problems mabe, crank sensor for instance could possibly cause this, its probably worth replacing the lot just to save a load of hassle in the future
Old Jan 19, 2007 | 10:11 PM
jon@work's Avatar
jon@work
As above, could well be a sensor problem - but also pull apart and inspect the engine management loom connectors in the engine bay as these regularly cause issues due to water/damp ingress.
Old Jan 19, 2007 | 10:13 PM
rapidcossie's Avatar
rapidcossie
any smoke out the back during this mate?
could be over fueling?
Old Mar 23, 2008 | 09:29 AM
spmotorsport
turned out to be the crank angle sensor, was holding by onl;y three maybe four strands of wire have replaced and goes like a cossie should
cheers for the help
hadyn
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fil
Sep 30, 2015 12:08 PM
cossie330
Sep 27, 2015 04:13 PM
