copper headgasket?
Old Jan 17, 2007 | 05:36 PM
mk4gartrac's Avatar
mk4gartrac
Default copper headgasket?
Thinking of buying a copper head gasket any views?
Or what should i go for ,looking at running 22psi or more
Old Jan 17, 2007 | 06:30 PM
Alvyn's Avatar
Alvyn
you do know that if you use a Coopers gasket you WILL have to have the block machined to accept the firing rings!
if that's ALL the psi your going to use then if it was me I'd go for a Group A one
Old Jan 17, 2007 | 06:53 PM
SafeChav's Avatar
SafeChav
Christian was running over 32psi on a standard ford gasket IIRC.
And from what ive heard its fairly common to lose coolant and oil as a result of the copper gasket, as you have to use sealants, which make it hard to get a good seal on the water and oil galleries
Old Jan 18, 2007 | 07:19 PM
mk4gartrac's Avatar
mk4gartrac
ok cheers thanks for the info
Old Jan 19, 2007 | 07:51 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
hi mate i was running 20 psi on a zetec turbo with a plate from ferriday engineering the plate was bonded to the block using a semi hardning sealing compound then on top of the plate is a ford head gasket then torqued down as normal
never failed on me so i would say
tommy
Old Jan 20, 2007 | 05:11 PM
SafeChav's Avatar
SafeChav
tommy
Thats a different kettle of fish though, as you've used it as a decompression plate so you can get away with bonding to the block, and the headgasket forms the seal to it.
hes talking about JUST a copper gasket.............
Old Jan 20, 2007 | 07:07 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
sorry mate never red it fully yip grp a should do for that
Old Jan 21, 2007 | 05:20 AM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Old Jan 21, 2007 | 11:39 AM
SafeChav's Avatar
SafeChav
Genesis Engineering, started off as copper mate (thought my reading was getting worse for a minute there )
Of all the information ive ever been passed back, everyone seems to use the decompression plates in addition to a gasket, which i have never liked the sound of.
If theres sealeants around that will actually seal up the galleries properly then its all good obviously
Bransby
Sep 21, 2015 05:29 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
220TC
Sep 11, 2004 08:13 AM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
