Fitting S2 RS TURBO Bodykit
Old Sep 5, 2004 | 09:13 AM
jedi0_3's Avatar
jedi0_3
Default Fitting S2 RS TURBO Bodykit
Can anyone suggest best way to fit this kit to a H Reg mk4 escort cabriolet. Rear arches just screw through in wheel arch, fine.My car has rubber side sill trim fitted which sits onto a metal plate fitted to car, i'm assuming that this plate is the same size & type as one fitted on S2 RS Turbo.
Front arches more of a pain, am I better bonding them on as opposed to drilling necessary holes in front wheel arches on car, if so what is best product to bond with.
Probably a dumb ass question to people in the know but rather ask the experts before hacking up the car!!
Thanks for any help
Old Sep 7, 2004 | 09:29 AM
CabrioTurbo's Avatar
CabrioTurbo
IMO it will be easier for you to just bond the arches onto the car (although mine has been properly rivveted on ) you can do this with stik-o-flex or similar. as regards to the side skirt you can just use selftapping screws to hold the botoom of the skirt in place
Old Sep 7, 2004 | 10:27 AM
jedi0_3's Avatar
jedi0_3
Thanks for the reply, my car has flat rubber side mouldings on the sills fitted onto a metal backing plate, I believe that these mouldings were std on the latter cars(mines H Reg), would you happen to know if the metal plate is the same one as supplied on the turbos to support the side sill extensions of the bodykit. Thanks Again!!
Old Sep 13, 2004 | 06:28 PM
Chr1s's Avatar
Chr1s
Don't know if it helps but on my RST the side skirts are held on by a plastic strip which is riveted to the sill, there are no metal plates holding the kit on!
The skirts fits down onto this plastic strip and then screw in underneath.
Chris
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 15, 2015 10:43 AM
