Turbo help needed
Old Dec 23, 2006 | 11:48 PM
khanny's Avatar
khanny
Default Turbo help needed
Any1 know if you can tighten the shaft in the turbo on a garret t3 og a s2 erst. just got a turbo no smoking or leaking of oil but the shaft has a fair bit of play any1 know if it can be tightened i just dont want it to do any seriouse damage and cant afford to get it reckoned cheers
Old Dec 24, 2006 | 07:47 AM
antony215's Avatar
antony215
Escort Rs Turbo
No if it's got shit loads of play then it's fucked and needs a rebuild/recon
Old Dec 24, 2006 | 10:28 AM
ram's Avatar
ram
Has a large member
you should of checked on here before you bought that! you cant tighten the shaft on a turbo. the first thing i always check on a turbo is play in the shaft!
Old Dec 24, 2006 | 03:13 PM
SafeChav's Avatar
SafeChav
Khanny, see your other thread and my response should hopefully shed some light on the situation
big_Rad
Sep 15, 2017 09:36 AM
muz
Aug 16, 2015 12:57 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
col93saphcos
Aug 7, 2015 03:21 PM
