Escort P8/L8
It was just a thought.. as I was reading some tech threads. Then it hit me ( notthat I will do it
)..With a L8 I would´nt need to take the ECU out of the car to get the modd, so I could use datastream IAW monitor.
No worry
will keep my P8.. and get the modd together with at new chip from MotorsportsDevelopment.
But thanks...
No worry
But thanks...
L8 is more reliable,
is that fair on the p8 though,,,
it shows up faults with the loom/car/sensors that may not be apparent with the l8, as the p8 drops into limp mode whereas the l8 doesnt - so it can feel like running a p8 makes the car less reliable when in fact its nothing to do with the ecu...
ah..
i thought the hardware of the p8 was superior wrt the l8, ie injecotr drivers, IIRC, stu told me that for the same spec engine a p8 wil give ever so slightly more power due to the beter injector drivers - - but i may well be wrong,,, ive done a lot of house bashing since then
Dr. Ickxs
Sep 15, 2015 10:15 PM
