coil overs
Old Dec 30, 2003 | 09:06 AM
alan rainbow's Avatar
alan rainbow
Default coil overs
any body know about fitting coil overs on the rear that are rose jointed do you have to drill the top mount out ect
Old Dec 30, 2003 | 01:20 PM
Gav Diamond's Avatar
Gav Diamond
I think that you can get spacers so you dont have to drill the top mount,
Phone people like A1 Rally or GGR, Woodfords etc.
HTH
Old Dec 30, 2003 | 02:07 PM
alan rainbow
cheers gav i phoned brom he sayed drill the top mount to take the 19mm bolt but when i bounce the car i get a knocking sound but seems alright when you drive it have you got a1 number
Old Dec 30, 2003 | 05:48 PM
Gav Diamond
If you do deside to drill it out make sure that it is spot on for size as you dont want the bolt to move as i will possibly make the whole bigger as it bounces up and down.(I may be wrong though)
A1 is on 01767 691 617 but they are closed till Jan 5th
Old Dec 30, 2003 | 05:49 PM
Gav Diamond
As for the knocking have you made sure its not the spring catching the inner arch as i had this problem with my Avo coilovers
HTH
Old Dec 30, 2003 | 06:40 PM
alan rainbow
it could be they are very close and the spaces i got with them dont fit in to the rose in any way they look like they are just bits of plastic tube cut to the right size if it is the springs catching how do you sort it
Old Dec 31, 2003 | 02:38 AM
Gav Diamond
If you jack the car up you should be able to see it touching, if it is that making the noise.
Think it will be on passenger side iirc.
The way i sorted mine was to heat up the metal with a blow tourch and hammer it in, but i wasn't keen on doing this
Old Dec 31, 2003 | 08:51 AM
alan rainbow
i will have ago the passenger side is very tight thats funny that they should be identical
Old Jan 2, 2004 | 05:50 PM
I hope you have a strutbrace at the rear between the inner wheelarches?
If not fit one because the chassis is not built for the loads you create with coilovers because the wheelarches now take the FULL vehicle weight instead of just the shocks.
If the wheel arches say BYE BYE you're looking a sh#tload of work.
Old Jan 3, 2004 | 01:33 AM
Gav Diamond
I know this is what people say
But how can a strut brace cure this as you will still have the same force on the rear turrets on lauching, or is the problem only on cornering?
Old Jan 3, 2004 | 12:33 PM
Danny B's Avatar
Danny B
Gav adding a rear Strut brace just allows the forces to be stread as the brace in effect ties in the 2 shock towers together along with the boot floor, which limits the amount of flex, also what I do when fitting Coil overs is to drill the hole out and also weld a 1/8" washer either side to stop the hole elongating.
Old Jan 3, 2004 | 04:03 PM
alan rainbow
danny i take it the washers are a 12mm hole i thought about doing this but dint want to get the welder in the car
marky_g
Sep 12, 2015 04:26 PM
gcfcos
Sep 11, 2015 06:03 PM
jonfoc
Sep 11, 2015 04:46 PM
dms04
Sep 11, 2015 01:57 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
