2wd t5 gear box help
Old Aug 29, 2004 | 09:01 AM
leesrs240's Avatar
leesrs240
Default 2wd t5 gear box help
A few months ago it started to get hard to select 4th gear when going up the box but if you were very slow or had two or three goes at it it would go in. If you were coming down the box it was no problem..
Now i cant get 4th at all going up or down
If i let the car tick over i can get 4th no problem when at a stand still
What do you think by the way the box is only 39000 miles from new
cheers lee
Old Aug 29, 2004 | 05:29 PM
alan rainbow's Avatar
alan rainbow
4th gear syncro mate needs sorting
Old Aug 29, 2004 | 05:44 PM
leesrs240's Avatar
leesrs240
Will that cost a lot and is there a reason for this to happen..
thanx lee
Old Aug 29, 2004 | 06:26 PM
alan rainbow
its just down to wear on the syncro ring you need to talk to a gear box place for cost the main problem is getting 5th gear off the shaft with out breaking it
Old Sep 2, 2004 | 02:08 AM
Switch's Avatar
Switch
I think for a "software rebuild by Bernie, its about £350 this includes syncos. 4th is where it usually goes on 2wd saffs
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Leyleeroy
44
Sep 20, 2015 08:48 PM
marky_g
17
Sep 2, 2015 08:44 PM
FlashRS
13
Aug 31, 2015 06:02 PM
