costina bottom hose
Old Nov 8, 2006 | 07:03 PM
poosboys's Avatar
poosboys
Default costina bottom hose
Hi, can anyone help, maybe a bit of a novice question but is the bottom radiator hose t-piece pipe that leads to the header tank on a 2wd cossie a return hose. i am fitting a cossie motor in my mk4 cortina and what i want to do is fit a one piece pipe with no t-piece between the radiator and water pump and the pipe that would normally T off run from the header tank to the overflow fitment on the filler neck of my radiator as i have fitted a grp 4 mk2 escort rad hence the fact i need to know if its a return hose. thanx , help me
Old Nov 9, 2006 | 07:18 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Shame its not a MkV as i have spare doors and glass for one.
Good luck with it
Heres a old pic of mine.
Steve.
Old Nov 9, 2006 | 08:34 PM
costina's Avatar
costina
Live long and prosper!!
No its not a return just a fill BUT you will need a return to the top of the rad for the Turbo and a swirl pot if you use one
A pic of mine(old pic)
Old Nov 11, 2006 | 09:15 AM
costina's Avatar
costina
You could use a standard pinto lower hose and top if they fit that will work fine with a return for turbo to the top of the rad
Old Nov 14, 2006 | 05:50 PM
poosboys's Avatar
poosboys
Default costina
Hi, im a bit lost with the bottom hose, you say i can use a pinto bottom hose which is what i need to do but where do i connect the pipes from the header tank to, obviously one goes to the turbo but where do i put the one that would go to the bottom hose sorry you lost me abit thanx for ya reply
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
