Saph 4x4 help required plz
Old Oct 12, 2006 | 09:06 PM
Steve111's Avatar
Steve111
Default Saph 4x4 help required plz
Couple of times car has conked out on me and wouldn't start again, then after a few trys would go and drive fine.
Have now noticed that when it conks out and I turn the ignition on, the fuel pump keeps buzzing away. Ignition in ON position without trying to start the car and when I touch the fuel line going into regulator you can feel it buzzing under pressure aswell. then eventually after a while the pump goes back to a normal one buzz type noise when ignition is turned to ON and the car will start and tick over and run fine ( untill the next random conk out )
Starting to really piss me off now, any idea's guys ??
Old Oct 13, 2006 | 08:36 AM
trevCOSS's Avatar
trevCOSS
fuel pump staying on like this is an indication of an ecu failiure of some type, could be you have a sensor that is braking down of a wiring problem. Fuel pump latch is definately a signal from the ecu telling you something is wrong. Mabe a code read would enlighten you to whats up with it.
Old Oct 14, 2006 | 11:45 AM
Steve111's Avatar
Steve111
Thks for reply, hope it's not the ECU that's faulty Can't afford a massive bill right now will try and get the codes read though and see if that shows anything.
