Mondeo ´95 24v V6
Old Sep 13, 2006 | 09:34 AM
JanDK's Avatar
JanDK
Default Mondeo ´95 24v V6
Does anyone know if I can make a diagnostic readout like on cossies with a LED??
Andhow to decode these signals??
My Mondeo have a VERY poor fueleconomy and began 2 weeks ago to fail starting, and it is exactly the same thing every time it fools around with me.
Turn the key.. in m.sec it goes to 2000 r/min.. drops sloooowwly to regular idle, coughing a little, then dies. Start again.. doing the same procedure and dies. starts again and for the most it is normal!!
It is allmost like it is pumping fuel in the pipeline to the rail... or??
Anyone
Old Sep 13, 2006 | 11:47 AM
dave green's Avatar
dave green
you need diagnostic equipment. to reed them
Dave
Old Sep 13, 2006 | 12:41 PM
JanDK's Avatar
JanDK
VERDAMT!!!
Thank you Dave
Old Sep 13, 2006 | 02:40 PM
sailorbob's Avatar
sailorbob
If you have an eec-iv ecu'd Mondeo I think you can make/use a basic LED tester as described here http://www.fordscorpio.co.uk/star.htm The STO/STI connector is a triangular 3 pin plug next to the octane adjust and DCL plugs fitted to the bulkhead (offside on UK models) of the engine bay.
Old Sep 13, 2006 | 02:57 PM
JanDK's Avatar
JanDK
Oki.. hmm. will look at it! It is a mondeo 24v v6.. I think it is eec-IV ecu
Old Sep 13, 2006 | 03:05 PM
sailorbob's Avatar
sailorbob
Missed it's the V6, it might have a similar connector to that described in the article hidden behind a panel on the dashboard.
Old Sep 14, 2006 | 04:33 AM
JanDK's Avatar
JanDK
Okay Sailor.. I will have a look. Thanks
Old Sep 14, 2006 | 06:35 AM
dave green's Avatar
dave green
Acording to auto data it has the 16 pin OBD conecDave
Old Sep 14, 2006 | 10:13 AM
JanDK's Avatar
JanDK
oki...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
The Enigma
Sep 29, 2015 10:31 AM
