battery draining.....HELP
Old Aug 21, 2004 | 02:01 PM
jamesy's Avatar
jamesy
Default battery draining.....HELP
Hi all can some one help.. Ive got a 4x4 saff and the battery keeps going flat ive found the fuse thats draining the battery but cannot trace the problem dus any one no of any good auto electrical so i can get it fixed cus ive been looking for days and its p*ssing me off PLEASE help.. im in the blackpool area .
Old Aug 21, 2004 | 06:57 PM
Jake_N's Avatar
Jake_N
My ex-saff had same problem . reason was trunk light , it was on all-the-time . It was fixed by installing a swith
Old Aug 24, 2004 | 04:07 PM
Dave Henshall's Avatar
Dave Henshall
ive heard of several simple ones that can cause this,
as jake say, boot light/ interior light is a favourite when the pin switches fail and short out. anaother is the tracker backup battery that has died, if one of the cells dies it can draw exessive current tryingot charge itself but to no avail and thus flattens the main battery, when ws the last time it had a tracker "audit" when they come and check the movement sensor, transmiter and battery? they recon every 5 years the yuasa dry cell battery needs doing on them.
Old Aug 24, 2004 | 09:45 PM
cossied's Avatar
cossied
Default battery
what does not work with the fuse out?
Old Sep 24, 2004 | 01:47 AM
roger drummond's Avatar
roger drummond
Where do I find the tracker battery in a 1995 cos Esc?? I have no idea
roger
Old Sep 24, 2004 | 06:32 AM
dave green's Avatar
dave green
get a test lamp disconect the one side of the battery the test lamp will light if u have a drain. pull every fuse till lamp goes out then you no what is drainning the battery
Dave
Nov 1, 2015 06:53 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
Flatlinedan
Sep 18, 2015 12:41 PM
