Fiesta RS Starting Prob....PLEASE HELP
Old Sep 1, 2006 | 09:37 PM
Mish's Avatar
Mish
Default Fiesta RS Starting Prob....PLEASE HELP
Took my mum out somewhere before...came back home. Nipped inside to grab something and left the car running.
Came back out, went for a drive and then came in, let it tick over to cool down then switched off.
Realised I had to move it so my dad could get his car in...turned the key to start...and nothing. No click, no sounds, no turnover...nothing at all.
HELP me
Old Sep 1, 2006 | 09:52 PM
DazC's Avatar
DazC
Hot and bothered starter motor. Probably on it's way out and could do with a heat shield.
So have you bought one now then?
Old Sep 1, 2006 | 09:55 PM
Mish's Avatar
Mish
Yes i've got one- and i've broke it already obviously
Reckon that's what it is....? Should I try it again in a bit when it's cooled down?
Old Sep 1, 2006 | 10:10 PM
bingham's Avatar
bingham
same thing happened to me 2 days ago and it was the alternator
Old Sep 1, 2006 | 10:14 PM
Mish's Avatar
Mish
Just started it and it started up fine...so i'll see how it is tomorrow....
ta guys
Old Sep 2, 2006 | 01:58 PM
a/rs/e's Avatar
a/rs/e
Just incase it doesn't work or you experience the problem again let me know and I'll show you a way you can get the car started
And no I'm not a car thief.
Old Sep 2, 2006 | 04:55 PM
cos jon's Avatar
cos jon
I had a fiesta turbo and had 5 alternators on it, that could be one option or the starter as another.
You can discount the starter by push starting it, if it fires up and runs as normal its probably that
When my alternators used to go it would run rough then just stall.
Old Sep 11, 2006 | 09:08 PM
daveselwood's Avatar
daveselwood
Default solenoid
it sounds like the solenoid or loose wire going to the solenoid
JoeyBoyden
Jan 4, 2024 02:36 PM
paceo
Feb 3, 2016 10:31 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
slammedorion
21
Aug 6, 2015 11:38 AM
