ST170/Mondeo Brake Pads
Guest
Posts: n/a
Is there any difference between the brake pads that are fitted to a Focus ST170 and those that are fitted to a Mk3 Mondeo?
More to the point will these fit a Mondeo?
http://cgi.ebay.co.uk/FOCUS-2-0-ST17...QQcmdZViewItem
Redumbdancy
Hmmm...
Saph cos 4x4 disks and mondeo v6 are the same - so i assume thier pads are the same too.
Now on a fiesta you can upgrade to saph 4x4/mondeo v6 brake setup - they will both fit under 15 inch alloys. But the st170 brake setup required 16inch alloys. I'd therefore assume they're different.
HTH
HTH
The pads are different. ST170 pads have the claw on the back of 2 of the pads, while all 4 of the Mondeo pads are identical with a flat back and 2 little clips on the sides.
