Injectors???
Old Aug 19, 2006 | 12:55 PM
JanDK's Avatar
JanDK
Default Injectors???
What would I get from ex. SIEMENS injectors instead of BOSCH ones...
I run 4 greens now and thinking of greys.. maybe... and thought maybe it would be better with SIEMENS...
What do you say??
Old Aug 20, 2006 | 11:51 AM
stevieturbo's Avatar
stevieturbo
C**t
Siemens injectors are defo very good...but I assume you have the means to adjust fuelling and control any new injector ?
I was using some Siemens 660cc in my car for a while ( non cossie ), at 4.5 bar base pressure, with up to 1.3 bar on top of that.
They worked perfectly for me....
Almost regretting changing them to larger 750cc RC Engineering injectors, but the others were too small.
Old Aug 20, 2006 | 05:18 PM
JanDK's Avatar
JanDK
Hi Stevie..
I am not sure I am understanding you correct... but I think you mean a new chip with new injectors.. then yes!! I have MA Developments closed loop in mind (with greys) but if I can get a simular and better injector, the tuner that makes the chip for me just have to know what injector it is i think. I have´nt got that much knowledge about injectors cc and type-names... so I dont know yet. Just want to get the best out of it.. if possible and affordable
Old Aug 20, 2006 | 05:25 PM
stevieturbo
C**t
Ultimately your power goals, will determine the flow rate of injector you need.
After that, you can choose from a variety of different makes.
That also assumes, thet someone does actually make a "chip" to suit whichever injector you choose.
Old Aug 20, 2006 | 06:24 PM
throttlebodiedzetecturbo's Avatar
Default injectors
Mate ring jamie at jamsport about siemens injectors. As far as i know he is doing a deal on them at the mo. Give him a call he will definatly help you out..
Old Aug 20, 2006 | 08:59 PM
JanDK's Avatar
JanDK
Thanks to both of you.. will make some research
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
NZWINRZ
Ford Focus RS
Jan 28, 2020 09:24 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
