cossie rear discs
Old Aug 18, 2004 | 05:32 PM
16vzetec's Avatar
16vzetec
Default cossie rear discs
i have cossie rear disc set up for my mk4.
does it alter the offset??
ive heard it might space the wheel out another 10mm??
Old Aug 18, 2004 | 11:59 PM
richm's Avatar
richm
it will space the wheels out by the difference in thickness of the disc centre and the original drum centre - approx 6mm each side from memory.
Old Aug 19, 2004 | 03:41 PM
16vzetec's Avatar
16vzetec
i heard it was 10mm each side which would make a problem for me as i was going to run 7.5j 17's with 50mm drop.
is there any other brake set ups that dont space wheels out??
Old Aug 19, 2004 | 04:03 PM
richm's Avatar
richm
as the disc mounts onto the front face of the hub (between wheel and hub) it will always add offset to the wheel compared to the drum - the centre portion of the drum that the wheel bolts against is pretty thin, 3mm most generally, disc bell will be a reasonable amount thicker than this - though I can't see the disc bell being thicker than the drum by much more than 6mm or so.
Old Aug 19, 2004 | 10:45 PM
16vzetec's Avatar
16vzetec
oh i forgot to put its a mk4 escort, so the sierra rear hub is bound to be slightly different on the offset side of things
Old Aug 19, 2004 | 11:34 PM
richm's Avatar
richm
it's only the sierra disc thickness that is relevant, the disc fits over the standard S2 Turbo or XR3i hub
Old Aug 20, 2004 | 10:23 AM
WutangRS's Avatar
WutangRS
yes it does space out but i heard it was 5/6mm, only. tbh its only gonna cuase probs on the outer archs which can be sorted it. as ur running 7.5s it should pull them slighty away from the inner arch which is much better IMO
atm
Sep 1, 2015 04:56 PM
YODI
Aug 30, 2015 01:12 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
