oem part #'s
Old Aug 12, 2006 | 02:57 AM
ebledden's Avatar
ebledden
Default oem part #'s
can anyone give me the oem part numbers to a few sensors?
MAP
Mass Air Flow
TPS
Camshaft Position
Temp
Old Aug 14, 2006 | 06:32 AM
JesseT's Avatar
JesseT
Old Aug 14, 2006 | 12:47 PM
Dave Henshall's Avatar
Dave Henshall
for what car?
if its a cossie - DONT bother getting themfrom ford - they will cost literally 5 times more than they actually are.
they are not ford parts, they are all magnetti marelli, most of the traders on here stock and sell them for a fraction of the cost of ford,
Old Aug 15, 2006 | 03:59 AM
ebledden's Avatar
ebledden
i need them for a sierra cosworth
Old Aug 16, 2006 | 03:47 AM
ebledden's Avatar
ebledden
ok guys i truley need some help with this, i need the oem part numbers to a sierra cosworth, i live in the US and i dont have anyway to find these out so any help would be very nice.
Old Aug 16, 2006 | 07:38 PM
Dave Henshall
FINIS codes for them all
water temp senssor for ecu :1639283
air charge temp sensor for ecu: 1639284
TDC sensor on bottom pulley :1639282
2 bar map sensor:1638311
TPS sensor(2wd): 1639312
TPS sensor (4wd):6909241
water temp sensor for dash board :6145143
ignition amp: 1637546
hth
Old Aug 16, 2006 | 07:45 PM
Dave Henshall
ithere uis no mass air flow sensor,,, it relies purely on MAP,
and the phase sensor is not listed as a sperate item, only a complete distributor ?!?
you would best be getting al of these parts form over here and having them shipped to you....
seriously, the price of a £20 sensor from a specialist is literally £100+ from ford
Old Aug 17, 2006 | 06:45 PM
ebledden's Avatar
ebledden
thanks for the help, these are the oem numbers and not aftermarket numbers right?
Old Aug 17, 2006 | 09:00 PM
Dave Henshall
yep, the FORD part numbers
Old Aug 17, 2006 | 09:05 PM
Dave Henshall
but here are some of the sensors own part numbers as refered to by the manufacturer - Magnetti Marelli.
air charge sensor : ATS04
coolant temp sensor: WTS05
crank/TDC sensor: SEN8D
4x4 TPS: PF09
2wd TPS: PF01
2 bar map sensor: APS02/03
Old Aug 17, 2006 | 09:09 PM
ebledden's Avatar
ebledden
Magnetti Marelli is this the equivalent of ford over there?
Old Aug 17, 2006 | 09:31 PM
Dave Henshall
no magnetti marelli actually make the components (including the ecu) for ford. they are not even badged as ford parts,
you wil notice that the ignition amp, starter motor, ecu and nearly all the engine sensors ona ford cosworth are made by MM.
the exact same MM parts are also used a quite a few other cars, lanci delta integrale, ferarri f40, etc
Old Aug 17, 2006 | 09:52 PM
ebledden's Avatar
ebledden
ok that helps very much
Old Aug 21, 2006 | 05:21 AM
ebledden's Avatar
ebledden
they didnt cross over is there anymore wrighting on the sencors?????
Old Aug 21, 2006 | 08:11 AM
Dave Henshall
nope, sorry,
those ford finis numbers should work though, they are taken from fords own parts system
Old Aug 21, 2006 | 08:53 PM
ebledden's Avatar
ebledden
ok i was hoping that there was
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
