still got boost probs please help
Old Aug 8, 2006 | 02:32 PM
cossie0_4's Avatar
cossie0_4
Default still got boost probs please help
i have a 2wd cossy saph it is running 4psi of boost runs fine but when i try and turn it up it will only give me 6psi and it hesitates and backfires as if its overboosting i have changed boost hoses taken turbo and actuator off to be checked all came back ok switched amal valve and fitted diferent boost gauge still doing same thing any ideas would be greatfull as i am very close to torching the thing cheers
Old Aug 8, 2006 | 03:19 PM
jon@work's Avatar
jon@work
If it backfires, then it sounds like an ignition problem.
Have you looked at the state of the spark plugs recently ? What are they gapped at ?
Old Aug 8, 2006 | 04:51 PM
Alvyn's Avatar
Alvyn
check the plug connections on the ecu also!
Old Aug 9, 2006 | 03:28 PM
Noisy Boy's Avatar
Noisy Boy
is it chipped?
Old Aug 9, 2006 | 03:50 PM
cossie0_4's Avatar
cossie0_4
i have checked the block on the ecu looks fine yes the car has a stage 1 baileys chip plugs are in a1 condition only recently changed they are gapped at 0.8mill motorcraft platinum thanks
Old Aug 9, 2006 | 03:54 PM
jon@work's Avatar
jon@work
0.8mm is perhaps a bit large - try reducing the gap to about 0.6mm
Old Aug 9, 2006 | 06:23 PM
turbodoctor's Avatar
turbodoctor
yes too big a plug gap will weaken spark n cause your cos to backfire like its over boostin
Old Aug 10, 2006 | 09:10 PM
cossie0_4's Avatar
cossie0_4
i have lowered plug gap to 0.6 still same prob also changed map sensor an pluged another ecu in still same cheers
Old Aug 11, 2006 | 02:41 PM
Dave Henshall's Avatar
Dave Henshall
all the time, or just on boost?
if just on boost = igniotion amp on its way out IF the plugs are ok...
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Russ Payne
Sep 25, 2015 08:29 PM
