XR3i Escort not charging?
Old Aug 5, 2006 | 07:42 PM
hutchyotb's Avatar
hutchyotb
Default XR3i Escort not charging?
my xr3i isnt charging the battery its not the alternator any help??
Old Aug 6, 2006 | 09:48 AM
richm's Avatar
richm
is the charging warning light lit when ignition is switched on? Does it go out when the engine is running? What voltage do you get measured across the battery when the engine is running?
Old Aug 6, 2006 | 10:54 AM
b_kennedy's Avatar
b_kennedy
had similar problem on my old 3i. turned out to be a bad earth.
Old Aug 6, 2006 | 04:33 PM
hutchyotb's Avatar
hutchyotb
light stays on wen the engines running. have no volt-meter to get the battery reading. took the eart off the alternator and cleaaned all the ends but still no joy
how you get your bad earth problem sorted?
Old Aug 6, 2006 | 06:14 PM
richm's Avatar
richm
if the light comes on with ignition and stays on, then it IS an alternator problem.
Old Aug 6, 2006 | 07:55 PM
hutchyotb's Avatar
hutchyotb
Thanks for the help. much appreciated
Old Aug 7, 2006 | 01:09 AM
b_kennedy's Avatar
b_kennedy
basically did what you did. Cleaned the earths and noticed that some of the smaller brown wires earthed to the body werent connected so crimped some new ones. Would imagine those small brown ones were a co-incidence but still like to think it worked lol
I did change alternator too!
Old Aug 7, 2006 | 04:06 PM
i had the same fault when i had an xr3 1t was a bad corroded wire on the battery live terminal
Old Aug 7, 2006 | 04:46 PM
hutchyotb's Avatar
hutchyotb
put the meter cross the battery today and it dropped wen i started the car so guna get a new alternator well reconditioned one
Old Sep 3, 2006 | 11:46 PM
JamboRS's Avatar
JamboRS
focus rs 1672
sorry to bring this back up
my battery light is glowin and my window wipers come on themselves,ive changed bat and alt twice and still no change,cleaned up all known earths,still no change,any ideas?
Old Sep 4, 2006 | 10:20 AM
SafeChav's Avatar
SafeChav
hutchyotb, i hope you get this before you get a recon alternator, check the thin blue wire running to the alternator first, could be as simpleas that being broken
AND if its not that, it will cost about Ł20 to fix your old alternator, much cheaper than paying Ł100+ for a new one
Old Sep 8, 2006 | 09:51 PM
cossie604's Avatar
cossie604
As the Chav said...check out the blue wire....it runs along the front subframe up to the starter motor and is very common to fail. The amount of fiestas/orions/escorts that the likes of the AA and RAC used to bring into me for alternator or batteries that they had diagnosed that only needed a minor repair to said blue wire If onyl it was as simple as that on modern stuff eh
Old Oct 22, 2006 | 12:47 PM
hutchyotb's Avatar
hutchyotb
thanks for the help got it goin eventually then to my horror the guy who had the car before me didnt tighten a head bolt dont really need to say no more but after all the bother i can say it was worth it
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
bigryrs
Sep 7, 2015 06:45 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
Adam Graham
Sep 6, 2015 06:04 AM
Bighandsuk
Sep 2, 2015 05:23 PM
